Portal for ArcGIS - Failed to import site. A JSONObject text must begin with '{' at character 0 of
1469
04-11-2022 08:09 AM
Oiligriv
Hello Community
I am restoring a Portal that has been damaged due to running out of disk space.
I have recovered the content and the DB and I am performing the restore.
the restore stops with the following error
do you have any ideas?
MattMoore
Did you ever find a solution to this? Have a customer that came across the same issue.
CodeSpatial
I have a similar issue but happens during webgisdr export and also while trying to export the site form AGS admin endpoint.
Export operation failed. A JSONObject text must begin with '{' at character 1 of
GiaNguyen2
Did you find a solution to this yet, I am also having the same issue.
MattMoore
In our case it was....
The accountSettings file located in ..arcgisportal\content\items\accountresources\0123456789ABCDEF\  was corrupt. When we checked the file size it was 0kb
Resolution:
We copied a backup of accountSettings from the content template: <installationfolder>\Portal\framework\template\content.zip, and replaced the corrupt accountSettings we then started the portal service.
