Point data not visible in new map viewer
849
06-06-2024 11:18 AM
CorrieGuynn
Hi all- I have point data that I have been plotting and using in the new map viewer on ArcGIS Online since it launched. Since a few days ago, this point data is not visible in the new map viewer. Nothing shows up when I open it.  When I open the map in map viewer classic or field maps, the data is visible and the symbology all present. In the new map viewer, I can still view the data's table too, having me believe it is present just not visible.
I have checked every setting I can think of. Even when I go into the layer itself and go to edit the symbology, nothing shows up as I change the icons. But if i do make changes, they are reflected in the classic map viewer and in field maps. What could be causing the icons to not be visible in the new map viewer?
Thank you in advance,
