patchnotification utility doesn't work since a few weeks
2111
04-16-2024 07:53 AM
dstrigl
Dear ESRI community,
we have the problem that the patchnotification utility doesn't work since a few weeks.
It can't find any patches and what's even more confusing: It doesn't recognize any installed components, although we have running ArcGIS Enterprise 11.1 with Portal for ArcGIS, ArcGIS Data Store and ArcGIS Server which all runs fine:
Under Windows Programs and Features we see the installed patches (that are missing in the patchnotification tool):
Regards,
Daniel.
dstrigl
Hi @JonSwoveland,
the problem were some corrupted ESRI registry entries in Windows.
We just repaired it by comparing it with the setup on another machine.
Regards,
Daniel.
Scott_Tansley
MVP Regular Contributor
I once saw this when the IT department changed the forward proxy settings.  At one client they introduced a forward proxy and it was necessary to configure the patch notification tool to negotiate the proxy.  The other side moved from a blacklist on their proxy to a whitelist. But didn’t add the rules for the proxy.   Might be a good start point as the tool is normally pretty robust.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
dstrigl
Hi @Scott_Tansley,
thanks for your response, but nothing changed at the proxy side and loading the patches.json using curl works!
curl --proxy "..." https://downloads.esri.com/patch_notification/patches.json
Regards,
Daniel.
JonSwoveland
Hi, just curious if you ever resolved this, and if so, how?
dstrigl
Hi @JonSwoveland,
Regards,
Daniel.
JonSwoveland
Hi Daniel, sorry for the delayed response.  Thank you for sharing that.  It was the same in our case.
