Parks and Rec Finder : Switch to SDE Connection
3180
8
08-22-2014 07:20 AM
BrianO_keefe
Regular Contributor II
I've got a blank LocalGovernment SDE database. Ready to go.
I decided to start with the Parks and Recreation Finder for ease of shifting into LGDM.
But when I downloaded this package, the MXD is already linked (with HUNDREDS of feature classes) to a LocalGovernment.gdb file?
Do I have to go in, individually, and change each layers pointer to my SDE connection? Or is there some master switch that I can run that will change out the GDB for my SDE?
Message was edited by: Brian O'keefe, Cleaned up for clarification
JakeSkinner
Esri Esteemed Contributor
JakeSkinner
Hi Brian,
You can right-click on the MXD in the catalog window > Set Data Source.  The MXD that contains the hundreds of layers is actually the basemap.  This can take some time to create since you have to populate all of the feature classes in the LGIM.  If your eager to stand up the app, what I recommend to customers is to use one of ESRI's basemaps in the application.  When your configuring the config file for the app, you can simply specify one of the basemap's REST URLs.
Now, you will just need to update the 2 layers in the Parks.mxd, publish this as a service, and you will be able to stand up the app.
BrianO_keefe
I'm getting weird errors.
Failed to load resource: the server responded with a status of 500 (Internal Server Error) http://maps.cityoftulsa.org/jsdev/ParksFinder/proxy.ashx?http://services.arcgisonline.com/ArcGIS/res...
It 'basically' won't load the esri maps? I did like you suggested tho, I used online maps for Basemaps instead of trying to corral some sort of makeshift basemap scenario. But it seems to be hanging up only on the http://maps.cityoftulsa.org/jsdev/ParksFinder/proxy.ashx?http://services.arcgisonline.com/ArcGIS/res...
Any ideas?
JakeSkinner
Did you configure the proxy?
Configure application - Get Started | ArcGIS for Local Government
Also, did you convert the application files to an application?
Publish application - Get Started | ArcGIS for Local Government
BrianO_keefe
Ok.
So I went back and I'm walking through the steps again.
My Map URL is: http://maps.cityoftulsa.org/ParksFinder/
I've even turned on my Geometry service on our server.
But I keep on getting the following error...
Unable to load reference overlay layer
Which, I've discovered, seems to be the Trails layer. Since I don't have the data for the GeneralPurpose.mxd nor the ImageryReferenceOverlay.mxd I am using ArcGIS options as follows...
BaseMapLayers
> topoMap > Topographic > http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer
> parcelMap > Streets > http://server.arcgisonline.com/arcgis/rest/services/USA_Topo_Maps/MapServer
> imageMap > Imagery > http://server.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer
Operational Data Settings
FacilityLayer > http://t1itpappgis02:6080/arcgis/rest/services/LGDM/Parks/FeatureServer/0
CommentsLayer > http://t1itpappgis02:6080/arcgis/rest/services/LGDM/Parks/MapServer/1
ReferenceOverlayLayer > http://t1itpappgis02:6080/arcgis/rest/services/LGDM/Trails/MapServer
But the error doesn't go away... I'm feeling kinda lost...
JakeSkinner
In the config.js file, go to line 144 and change the DisplayOnLoad to 'false'.  Ex:
ReferenceOverlayLayer: {
        ServiceUrl: "http://server1/arcgis/rest/services/Trails/MapServer",
        DisplayOnLoad: false
BrianO_keefe
Done.
I'm getting the following error in my JS Console...
Failed to load resource: the server responded with a status of 500 (NameResolutionFailure) http://maps.cityoftulsa.org/ParksFinder/proxy.ashx?http://t1itpappgis02:6080/arcgis/rest/services/LG...
Confused.
JakeSkinner
Did you convert the app files to an application in IIS?
BrianO_keefe
Fixed it!
I was using an internal server path... switched over and now it's up...
Of course, now I am getting a new error... lol. Ugh!
( Thanks for the help, by the way )
