Notebook server on linux not start container
3451
06-08-2021 05:38 AM
Oiligriv
Hello
I installed Arcgis Notebook Server on Red Hat Enterprise with the docker component.
The whole setup seems to work just fine.
but when I cast a Cantainer I get an error
RFIAPPLBS01LE.RFISERVIZI.CORP - Failed to create and start a Docker Container. 'Failed to create and start a Docker Container. 'Request error: POST unix://localhost:80/containers/5fb406e300e02d5bdca8aedd54de893990ec73853cf64a687c23d6648a9724b0/start: 500, body: {"message":"driver failed programming external connectivity on endpoint f4b8f3d4bbfc457881bbff66102886db (75031b2d807bb82c6fdf5d3fe1fea9776efec5341382a702dde6805355108563): Error starting userland proxy: listen tcp6 [::]:30001: socket: address family not supported by protocol"}'.'.
Investigating I found that on the server, IPV6 is disabled.
which solution is the best?
1) enable ipv6 on the server?
2) disable ipv6 on docker or container?
Thanks
JonEmch
Hey there,
   Did some research on this, and found that running * Activate ipv6 in / etc / grub * update-grub * reboot may resolve thi sissue.
Keep on keeping on!
JonEmch
Hey there,
Keep on keeping on!
Oiligriv
is it possible to disable IPV6 from docker?
JonEmch
You can according to https://mailcow.github.io/mailcow-dockerized-docs/firststeps-disable_ipv6/, but im not sure if that is the best move.
Keep on keeping on!
Oiligriv
Hi JonEmch
we have enabled IPV6 on the Loopback network card.
ArcGIS Notebook server is now able to successfully initialize Containers
Thanks
JonEmch
Great to hear! Glad I could help.
Keep on keeping on!
