Not Registered Database ArcGIS Server
2206
8
01-25-2023 09:42 PM
UğurcanGül
Hello,
I've created my sde database in ArcGIS Pro without any problems. When I import this in server manager>site>datastores, I get the attached error.
"A required property is missing or the property value is not recognized in the connection property setting. Invalid link attribute.[ ]"  The missing parameter encrypted password appears.
Portal version 11.0
using db postgresql
arcgis pro version 3.0
George_Thompson
Esri Notable Contributor
In ArcGIS Pro you need to create a Database connection. When you do this, make sure the "Save Credentials" option is checked. You then can use that .sde file to import as a DataStore.
look at Step 7: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-postgresql/connect-postgresql...
--- George T.
George_Thompson
Is Server and PostgreSQL on the same machine?
I noticed that you put "localhost" in the connection properties. If they are on different machines, you will need to make sure to update the pg_hba.config file to allow access: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-postgresql/configure-postgres...
--- George T.
UğurcanGül
Yes, all deployment(portal,ds,server and psql) on the same machine. I made all the necessary changes in pg_hba.config file. But Im getting still same error.
George_Thompson
Is the password saved in the connection file that was imported for the registration?
What is the version of PostgreSQL being used?
What is the version of the Enterprise Geodatabase?
--- George T.
UğurcanGül
The password is not registered in the attributes of the sde file imported for registration. Postgresql 12 is in enterprise geodatabase version 11.
George_Thompson
Ah, ok. You may need to save the credentials in the "<name>.sde" file then import it.
You can create a local version of the .sde file if you are worried about security.
--- George T.
UğurcanGül
how do i import credentials(only password-encrypted attribute) to sde file? I have no problem with security.
George_Thompson
--- George T.
UğurcanGül
Thanks, solved 🙂
