Is there anyone who had migrated ArcGIS Enterprise data from one version of software packages to another. We are trying to migrate the data from ArcGIS Enterprise 10.6 to 10.7.1. Any help will be appreciated.
-Tsering
Tsering Shawa, Have a look at the Esri help document: Link
Below is an extract.
1. You start by backing up your existing ArcGIS Enterprise using the following tools:
2." Perform the upgrade steps for each ArcGIS Enterprise software component in the following order:
Shelley,
Thanks for reaching out to me.
We worked with the Esri ArcGIS Enterprise tech support in upgrading our ArcGIS Enterprise from 10.6 to 10.7.1. We managed to upgrade the Portal, both web adapters, and the server, but failed to upgrade Data Store. We got a message saying the Database upgrade failed. The tech support suggested that we create a new VM, install ArcGIS Enterprise 10.7.1, and move the content from the production server (where the ArcGIS Enterprise 10.6 was installed) to the ArcGIS Enterprise 10.7.1. Once that is done and everything looks good, then we can uninstall 10.6, reinstall 10.7.1, and move content to the production server.
I thought of using Export Site and Import Site options in ....portal/portaladmin or the Webgisdr tool but I was told by another Esri tech support who was trying to help us migrate data we can't do this. In order to use those tools we need to have the same version of ArcGIS Enterprise which we don't have right now. What options do we have now?
-Tsering
