Max number of features in an input FeatureSet?
1391
04-11-2014 08:30 AM
ToddBryan
We have a geoprocessing service with the following signature:
Parameter: Features
Data Type: GPMultiValue:GPFeatureRecordSetLayer
Display Name Features
Description: Input feature set.
Direction: esriGPParameterDirectionInput
Default Value:
Parameter Type: esriGPParameterTypeRequired
Category:
Parameter: Output
Data Type: GPDataFile
Display Name Output
Description:
Direction: esriGPParameterDirectionOutput
Default Value:
Parameter Type: esriGPParameterTypeDerived
Category:
This GP service converts all the FeatureSets in the input to one shapefile.  The actual Python code for the service is dead-simple:
import sys, os, arcpy
features = arcpy.GetParameter(0)
output = os.path.join(arcpy.env.scratchWorkspace, "ssexport.shp")
arcpy.CopyFeatures_management(features, output)
arcpy.SetParameter(1, output)
We are calling this service with an array of one FeatureSet. That FeatureSet has N features.  The service runs properly when N <= 2000, but when the number of features in the FeatureSet exceeds 2000, the GP script fails with "The workspace is not connected."
There seems to be a limit of 2000 on the number of features in an input feature set.  Note that this IS NOT the well-known 1000 feature output limit.  Our research in the docs and online reveals no mention of such an input limit, and our careful search of the entire ArcGIS Server configuration directory reveals no server setting for this input limit.
Can someone speak to the existence of this limit and suggest a way to change or circumvent it?
Many thanks -
Todd
RalfSchmidt
Just in case someone else also visits this page: A few days ago I had the very same problem and it turned out to be a bug in ArcGIS Server, still present in 10.5.1.
Esri Inc. now records this as
BUG-000107968 -- Running geoprocessing service with more than 2000 output features causes geoprocessing failure with the error message "The workspace is not connected".
Please note that the text is not completely correct: It's the number of input features – not the number of output features – that causes problem.
RebeccaStrauch__GISP
I converted the thread from a discussion to a question, which typically gets more views/response.  I will mark Ralf's answer as the correct answer since he listed the bug (and it still exists).
trbryan   if you are still having issues and/or found a workaround, a summary would be helpful for others (and you can change the correct-answer selection if needed).
JonathanQuinn
Esri Notable Contributor
Are you running this through REST or SOAP?  The bug details seem to imply that REST works, but SOAP is the problem.
