Map service periodically crashes (ArcGIS for Server 10.1 SP1)
6116
9
07-23-2013 12:32 PM
DahaeHwang
We are experiencing periodic crashing of map services on request - it occurs randomly about 5 -10 times during a day... We have map services connecting to both Oracle and Postgresql databases thru SDE direct connections, but it seems not a matter of which database it is accessing to.
We are using clustered GIS Servers under AGS Web adaptor in a virtual environment, and refresh(Stop/start) AGS Services every morning on the servers.
When it crashes, the used memory on the server is less than 70%... (Max 8GB is allocated to each GIS machine)
I've attached the dump files from error report.
Any hep would be appreciated.
Thanks in advance,
RichardWatson
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//003z00000150000000
EXCEPTION_RECORD:  ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 0000000074801609 (ServerContainer!CServerObjectFactoryX::AddAddInFolder+0x0000000000000019)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000000
Attempt to read from address 0000000000000000
This says that the function AddAddInFolder is being called with a NULL pointer for the argument addInFolderPath.
DahaeHwang
Thanks for your help, Richard.
So the exception indicates that 'AddAddInFolder' method was called without 'addInFolderPath' parameter...
I am still trying to understand what 'IServerObjectFactoryX.AddAddInFolder' does and where it is called.
Is this the 'AddInFolderList.xml' in C:\Users\username\AppData\Roaming\ESRI\Server10.1? Is this method supposed to be called by default when creating a new instance on the server..?
Thanks again,
Dahae
RichardWatson
This is what C:\Users\arcgis\AppData\Roaming\ESRI\Server10.1\AddInFoldersList.xml looks like on my machine:
<?xml version="1.0"?>
<ESRI.ArcGIS.AddInFolders ver="1"><ARCSOC/></ESRI.ArcGIS.AddInFolders>
What does it look like on yours?
Note that mine is under user arcgis because that is the default account that ArcGIS Server uses.
I do not know what ESRI is, or is not, supposed to do.  My >guess< is that you have some type of configuration error and we are trying to debug it by reverse engineering from the failure.  Sometimes that works well, sometimes it does not.
DahaeHwang
Thanks Richard.
Yes. Mine looks same as your xml file... Thanks for the info and I will keep reserching on this crashing issue.
RichardWatson
Maybe you upgraded a site from version 10 (or earlier) and have registry settings which need to be cleared out?
http://gis.stackexchange.com/questions/2406/why-are-my-additional-add-in-folders-disappearing
This is pure guess on my part.  I have a clean 10.1 SP1 machine (not upgraded from 10) and cannot find an AddInFolders registry key on my machine.
DahaeHwang
We had a clean 10.1 installation too... I checked the registry and it didn't have a key for AddInFolder.
Thanks for the suggestion.
AnthonyGiles
Honored Contributor
Dahae,
Not sure if it is related but there was a patch released last week which fixes services becoming locked:
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/66/metaid/1991
Regards
Anthony
DahaeHwang
Thanks Anthony.
I will give a try.
DahaeHwang
Okay, I installed the new patch but am still getting the crashing errors.
The debugged logs were as below... it was crashed @13:26:25 when tried to create instance of service.
I am not sure if this is related to a known bug with clusted GIS machines.
I've attached the dump file from this error.. Any help/suggestion is appreciated.
<Msg time="2013-07-26T13:26:22,153" type="DEBUG" code="9999" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Creating server context. Isolation level = LOW.</Msg>
<Msg time="2013-07-26T13:26:22,379" type="INFO" code="8270" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Creating instance of service 'Maps/ServiceName.MapServer'.</Msg>
<Msg time="2013-07-26T13:26:22,470" type="DEBUG" code="9999" source="Server" process="14516" thread="17" methodName="" machine="ServerName" user="" elapsed="">Starting worker thread to host server object.</Msg>
<Msg time="2013-07-26T13:26:22,472" type="DEBUG" code="9999" source="Server" process="14516" thread="17" methodName="" machine="ServerName" user="" elapsed="">Start - initializing engine</Msg>
<Msg time="2013-07-26T13:26:22,474" type="DEBUG" code="9999" source="Server" process="14516" thread="17" methodName="" machine="ServerName" user="" elapsed="">End - initializing engine</Msg>
<Msg time="2013-07-26T13:26:22,977" type="DEBUG" code="9999" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Creating server context. Isolation level = LOW.</Msg>
<Msg time="2013-07-26T13:26:25,376" type="SEVERE" code="8273" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Services containing process crashed. Maps/ServiceName.MapServer instance has crashed.</Msg>
<Msg time="2013-07-26T13:26:25,377" type="DEBUG" code="9999" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">java.lang.Exception: Maps/ServiceName.MapServer instance has crashed.
at com.esri.arcgis.discovery.ejb.util.EJBBase.initService(EJBBase.java:365)
at com.esri.arcgis.discovery.ejb.util.EJBBase.init(EJBBase.java:219)
at com.esri.arcgis.discovery.ejb.util.EJBBase.init(EJBBase.java:154)
at com.esri.arcgis.discovery.ejb.impl.GenericServerBean.init(GenericServerBean.java:51)
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:162)
at org.apache.openejb.core.interceptor.ReflectionInvocationContext$LifecycleInvocation.invoke(ReflectionInvocationContext.java:194)
at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:144)
at org.apache.openejb.monitoring.StatsInterceptor.record(StatsInterceptor.java:164)
at org.apache.openejb.monitoring.StatsInterceptor.PostConstruct(StatsInterceptor.java:101)
at sun.reflect.GeneratedMethodAccessor60.invoke(Unknown Source)
at org.apache.openejb.core.interceptor.InterceptorStack.invoke(InterceptorStack.java:122)
at org.apache.openejb.core.stateless.StatelessInstanceManager.ceateInstance(StatelessInstanceManager.java:237)
at org.apache.openejb.core.stateless.StatelessInstanceManager.getInstance(StatelessInstanceManager.java:167)
at org.apache.openejb.core.stateless.StatelessContainer.invoke(StatelessContainer.java:165)
at org.apache.openejb.core.stateless.StatelessContainer.invoke(StatelessContainer.java:136)
at org.apache.openejb.server.ejbd.EjbRequestHandler.doEjbObject_BUSINESS_METHOD(EjbRequestHandler.java:238)
at org.apache.openejb.server.ejbd.EjbRequestHandler.processRequest(EjbRequestHandler.java:129)
at org.apache.openejb.server.ejbd.EjbDaemon.processEjbRequest(EjbDaemon.java:196)
at org.apache.openejb.server.ejbd.EjbDaemon.service(EjbDaemon.java:149)
at org.apache.openejb.server.ejbd.EjbServer.service(EjbServer.java:71)
at org.apache.openejb.server.ejbd.KeepAliveServer$Session.service(KeepAliveServer.java:213)
at org.apache.openejb.server.ejbd.KeepAliveServer.service(KeepAliveServer.java:233)
at org.apache.openejb.server.ejbd.EjbServer.service(EjbServer.java:66)
at org.apache.openejb.server.ServicePool$2.run(ServicePool.java:91)
at org.apache.openejb.server.ServicePool$3.run(ServicePool.java:120)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.rmi.UnmarshalException: Error unmarshaling return header; nested exception is:
java.net.SocketException: Connection reset
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:227)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:160)
at sun.rmi.server.ActivatableRef.invoke(ActivatableRef.java:142)
at java.rmi.server.RemoteObjectInvocationHandler.invokeRemoteMethod(RemoteObjectInvocationHandler.java:194)
at java.rmi.server.RemoteObjectInvocationHandler.invoke(RemoteObjectInvocationHandler.java:148)
at $Proxy43.createService(Unknown Source)
at com.esri.arcgis.discovery.ejb.util.EJBBase.initService(EJBBase.java:342)
... 34 more
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:189)
at java.net.SocketInputStream.read(SocketInputStream.java:121)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
at java.io.BufferedInputStream.read(BufferedInputStream.java:254)
at java.io.DataInputStream.readByte(DataInputStream.java:265)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:213)
... 40 more
</Msg>
<Msg time="2013-07-26T13:26:25,606" type="DEBUG" code="9999" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Cleaning up previous service instance and server context.</Msg>
<Msg time="2013-07-26T13:26:26,487" type="INFO" code="8270" source="Server" process="5608" thread="1" methodName="" machine="ServerName" user="" elapsed="">Creating instance of service 'Maps/EarlyAssistance.MapServer'.</Msg>
<Msg time="2013-07-26T13:26:26,807" type="DEBUG" code="9999" source="Server" process="16252" thread="17" methodName="" machine="ServerName" user="" elapsed="">Starting worker thread to host server object.</Msg>
<Msg time="2013-07-26T13:26:26,823" type="DEBUG" code="9999" source="Server" process="16252" thread="17" methodName="" machine="ServerName" user="" elapsed="">Start - initializing engine</Msg>
<Msg time="2013-07-26T13:26:26,927" type="DEBUG" code="9999" source="Server" process="16252" thread="17" methodName="" machine="ServerName" user="" elapsed="">End - initializing engine</Msg>
