Map Packages and Geometric Network
644
07-16-2020 07:57 AM
higgy7
When i try the share as map package tool i get the general function errors, I am using SDE data but i am ticking to include this data instead of referencing.
I have also tried to create a map package using the Package Map geoprocessing tool. When i do this i also set to include data and i am setting an extent. In this case i get the following error:
The data contains a geometric network and i was wondering if this is what is causing the error? When i reference the data it works fine but it does not clip the data to the extent set.
The data i am trying to package is as follows:
Settings as follows:
Any help greatly apprenticed. Thanks
Tags (1)
