I'm trying to use the Manage Map Cache Tiles geoprocessing service that comes out-of-the-box with ArcGIS 10.1 for Server, and I've been getting this error: ERROR 001428: Failed to retrieve configuration for service [insert URL here]. The service itself seems pretty self-explanatory, but I haven't been able to find any documentation on these services so that I can verify that I'm passing in the right parameters. I'm assuming you use the REST Map Server URL, put in the list of scales, number of caching instances, and select the Update Mode. I think the issue is the URL, but I'm copying it directly from my REST endpoint and don't understand wha the issue might be.
Could anyone direct me to some documentation or examples they've found, or share your experiences with this tool?
Thanks!
