Low isolation and maximum number of instances
5930
10
01-09-2019 02:31 AM
KubaSzostak1
I have read Tune and configure services—Documentation | ArcGIS Enterprise but still I need some clarification. What happens with pooling when I set in Processes section low isolation?
Processes section
Instances per process (low isolation only): 8
Pooling section
Maximum number of instances per machine: 4
Does it means there will be only one ArcSOC.exe process for this service? As I guess there will be 4 instances in one ArcSOC.exe process .
Maximum number of instances per machine: 12
Does it means there will be 2 ArcSOC.exe processes for this service? As I guess there will be 8 instances in one ArcSOC.exe process and 4 instances in second ArcSOC.exe process.
nicogis
MVP Alum
From 10.7 you can use shared instances Introducing shared instances in ArcGIS Server 10.7
