Linux: Error trying to connect web adaptor to portal
3109
03-03-2020 12:06 AM
AndrewClark2
I am setting up an ArcGIS portal 10.7.1 in Linux (Centos 7) and am running into an issue trying to configure the web adaptor. I am using a domain from godaddy and have it setup with the A names for www, portal, and @ (and they all work). I have apache SSL and Tomcat connected through a JK_mod connector. I have also installed Portal on the server and can access it through https://localhost:7443/arcgis/home.
My issue is that when i open the ArcGIS Web Adaptor 10.7.1 it gives me the following message: Unable to configure the ArcGIS Server with the Web Adaptor. Please make sure that the server machine is running and that the account specified has administrative privileges to the site.
I cannot figure out the error message and why it is not working.
The Tomcat Log shows a few error messages that might help figure out the problem:
Mar 03, 2020 2:50:42 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /var/lib/tomcat/webapps/portal.war has finished in 1,880 ms
Mar 03, 2020 2:50:46 AM com.esri.arcgis.server.wa.data.Config initialize
WARNING: Unable to load web_adaptor.properties configuration file
Mar 03, 2020 2:50:46 AM com.esri.arcgis.server.wa.servlet.WebAdaptorConfigServlet service
SEVERE: null
Mar 03, 2020 2:50:50 AM com.esri.arcgis.server.wa.servlet.WebAdaptorConfigServlet service
SEVERE: null
Thanks in advance of your help!
Andrew
FabianoScardua
I'm having the same problem.
KlausWieland
Same here with 10.6.1 and suse 12
Is catalina.out of your Portal saying the same?
Caused by: com.esri.arcgis.discovery.json.JSONException: A JSONObject text must begin with '{' at character 1 of ...
        at com.esri.arcgis.discovery.json.JSONTokener.syntaxError(JSONTokener.java:454)
FilipeArão
Not solved? I have the same problem here.
