last_edited_user populate
2554
08-03-2016 10:07 AM
JamesLandwehr
I would like to populate the last_edited_user field using a variable generated from a third party workflow. Is this possible? It continues to pull the SDE versioned user name and ignore my attempts to do a field update with a variable username collected from an authenticated login.
JoeBorgione
I've used this Sql Server trigger on the 'A' table of my centerlines for a number of years:
USE [vecc2012]
GO
/****** Object:  Trigger [vecc].[centerlineseditor]    Script Date: 8/3/2016 11:15:51 AM ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
-- Author:        <Author,,Name>
-- Create date: <Create Date,,>
-- Description:    <Description,,>
ALTER TRIGGER [vecc].[centerlineseditor]
   ON [vecc].[a28]
   for INSERT
AS update vecc.a28
--BEGIN
    -- SET NOCOUNT ON added to prevent extra result sets from
    -- interfering with SELECT statements.
    --SET NOCOUNT ON;
    -- Insert statements for trigger here
    Set editor = user
    where objectid in (select objectid from inserted)and user <> 'vecc'
--end
It just grabs the user-name to populate the field (unless the user is vecc; that's me);  How does the the third party user name differ from what you are getting?
That should just about do it....
JamesLandwehr
Joe, Thanks for your reply. My SDE Version is web_editor (so everybody's edits are shown as web_editor) and my User authenticated logins are email addresses.
JoeBorgione
I'm  a little confused (nothing new...):  it's pulling the name of the version and not the name of the user?  Does the third party handle the authentication or the database?
JamesLandwehr
As it turns out, the data model we're using has a LASTEDITOR field that honors the user authenticated id, so it will do as a workaround. But in answer to your question, the user authentication gives them access to the application which is running on a secured service - an SDE versioned feature service with a single editor. I think SDE is taking over the population of those editor tracking fields, but as I mentioned, I've got a decent workaround for the moment.
