Label Levels Not Consistent between Map Viewer and ExB
77
yesterday
YRP_GIS
I'm currently configuring an Experience Builder application and am having issues with my labels. Initially, my labels are set in ArcGIS Pro prior to publishing the layer to Portal (Hosted). When I view the labels in map viewer, they label as expected, however, when I open the layer in Experience Builder, there is a zoom extent that is being missed by both labels sets.
Image 1, 2, and 3 show the zoom extents of both of my label classes. In image 2 you can see how neither turn on given that there is a small overlap in their extent settings on the right hand side.
Image 4 is what is visible in my Experience Builder application.
For reference I'm on Enterprise 11.4. Is there some sort of labeling bug, or is there a more straight forward way to determine what the scale is on the map viewer map vs. Experience Builder map?
Laura
by MVP Regular Contributor
Esri article for this: https://support.esri.com/en-us/knowledge-base/problem-label-classes-overlap-at-different-zoom-levels...
I think you have your labeling properties set too close together. It could help to use actual scale numbers rather than street, town, etc. related: https://community.esri.com/t5/arcgis-experience-builder-questions/overlapping-label-classes-in-exper...
