Kill Process Windows Access Denied
3136
5
11-03-2021 01:37 AM
Oiligriv
I stop ArcGIS Server but some ArcSOC services remain operational.
some can be killed normally, while others ArcSOC gives me the Access Denied error.
has this ever happened to you?
JonathanQuinn
Esri Notable Contributor
You are likely running into
BUG-000134656 When stopping the ArcGIS Server service, all ArcSOC.exe (SOC-Processes) are not removed and do not stop running
Which is resolved at 10.9.1.
MichaelVolz
Esteemed Contributor
What type of ArcSOC services are problematic to kill (e.g. mapservices, geoprocessing services, geocoding services)?
Are you having issues with services that require you to kill them as opposed to stopping them thru Server Manager?
Oiligriv
Hi micheal
unfortunately I haven't opened the task manager command line, so I don't know which services are involved specifically.
if the same anomaly occurs again, I will try to retrieve the information.
I can only tell you that I found the ArcGIS Server service stopped inexplicably and these ArcSOCs Still alive.
DominicRobergeIADOT
Hey
I am curious, what version of ArcGIS Server are you running? I have a similar issue on one of our server running 10.6.1. Thanks!
Oiligriv
JonathanQuinn
