It´s possible to use ArcGIS Server without Portal installed?
1803
06-28-2019 06:21 AM
SoratoSouza_e_Silva
Occasional Contributor II
Hi everybody!
I´m new in ArcGIS Enterprise! I would like to know if possible use ArcGIS Server without Portal...If possible, what´s the mains differences?
Thank´s
André
Tags (1)
George_Thompson
Esri Notable Contributor
It is "possible" but not recommended as you will not have all the capabilities that are part of the full ArcGIS Enterprise deployment.
Here is a link that talks about it from the ArcGIS Server perspective; https://enterprise.arcgis.com/en/server/latest/get-started/windows/what-is-arcgis-for-server-.htm#ES...
What would you like to do with the deployment?
--- George T.
George_Thompson
--- George T.
SoratoSouza_e_Silva
Really I need understand correctly for learning. I would not want to do anything...Helped me a lot. Thank´s
DerekLaw
Esri Esteemed Contributor
Hi André,
While this is an older technical article, it does help convey why we encourage users to adopt the "Web GIS" pattern over just installing a stand-alone Server site, https://community.esri.com/docs/DOC-3385
Hope this helps,
SoratoSouza_e_Silva
Fantastic your article!! Help a lot!
I´m very grateful for your contribution!
Thank´s
André
