Long time searcher / first time poster...
I am unable to utilise the inbuilt manageservice utility (https://enterprise.arcgis.com/en/server/latest/develop/linux/manage-service-utility.htm) to check the status of specific services running on ArcGIS Server 10.9.1 when installed on the Linux Ubuntu 20.04 Operating system.
eg: <ArcGIS Server installation location>/arcgis/server/tools/admin/manageservice -u admin -p admin -s http://gisserver.domain.com:6080 -n Fire -o status
configuredState: STARTED
realTimeState: STARTED
When attempting to check the status of a service using the "-o status" option, the below python error is returned:
File "/arcgis/server/tools/admin/.admin/manageservice.py", line 4, in <module>
_server_admin.admin.cmdline.manageservice()
File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\_server_admin\admin\cmdline.py", line 90, in fn_
return fn(ActionNarrator())
File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\_server_admin\admin\cmdline.py", line 269, in manageservice
for key, item in sorted(service.status.iteritems()):
AttributeError: 'dict' object has no attribute 'iteritems'
The manageservice utility still successfully starts and stops services using the "-o start" and "-o stop" commands and using the "-l" option I can list the status of all services running on the server.
As a side note, I did notice that when using this utility briefly on ArcGIS Server 10.8.1 checking the status of a large amount of services in a scripted fashion for monitoring purposes python there were spikes in CPU utilisation (and responding with timeouts in a way we do not experience in ArcGIS Server 10.6.1).
A ticket has been logged regarding this issue, but thought i would put it out to the community as well incase someone is aware or has a way around this while i wait for a response.
Thanks!
