Issue with ArcGIS Data Store Validation and RecoveryFailed Status
258
6
3 weeks ago
Kristofer
Hi Team,
I am facing an issue with the ArcGIS Data Store and would appreciate your assistance in troubleshooting it.
Enterprise Version - 12.1
When I try to validate the ArcGIS Data Store Relational Datastore from the ArcGIS Server Admin page, I receive the following error:
"Server machine returned an error. 'The requested resource could not be found in the system. Please check the parameters and try again."
However, when I validate the Relational Data Store from ArcGIS Server Manager, the validation completes successfully
Additionally, when I run the describedatastore.bat utility to check the ArcGIS Data Store status, it reports RecoveryFailed.
Thanks & Regards,
Kristofer
JakeSkinner
Esri Esteemed Contributor
Hi @Kristofer,
Are your hosted feature services functioning correctly?
Do you have a recent backup of your Relational Data Store?
Kristofer
Hi @JakeSkinner ,
Are your hosted feature services functioning correctly? - Yes all the Services running properly.
Recent Backup - We have VM level backup. Don't have the ArcGIS Datastore backup. We are tried to take backup after upgradation from 12.0 to 2.1 but at a certain point (approx. - 80%) of time its failed.
Regards,
Kristofer
JakeSkinner
@Kristofer are you able to create a webgisdr successfully?  The below link may be of assistance:
https://community.esri.com/t5/arcgis-enterprise-documents/automate-arcgis-enterprise-backup/ta-p/914...
OlaIHamed
Hello @Kristofer
The fact that validation works from Server Manager but fails from the Server Admin page is interesting.
A few questions to help narrow this down:
  1. Is this a single-machine or multi-machine deployment?
  2. What service account is running ArcGIS Data Store and ArcGIS Server (local account or domain account? If it's a local account, there can be permission and authentication issues between machines. Domain accounts are generally recommended.
  3. Were there any recent changes? Machine restart, password change on the service account, certificate update, disk space issues, or Windows updates?
In the meantime, here's what I'd check:
ArcGIS Server logs:
Check the server logs  for the exact error behind that "requested resource could not be found" message. Look for entries around the same timestamp as your failed validation - the detailed error will tell you exactly which resource/endpoint it couldn't find. Also, check the logs when you validate from the ArcGIS Manger Home interface,
ArcGIS Data Store logs:
Check the logs at <Data Store install directory>\logs\<machine name>\server\ - there should be entries related to the recovery failure.
Check disk space on the Data Store machine - RecoveryFailed can sometimes be caused by insufficient disk space for the PostgreSQL recovery process
Also, can you share the full output of describedatastore.bat? That will show the exact state and any details behind the RecoveryFailed status.
Kristofer
  1. Is this a single-machine or multi-machine deployment? - No, This is multi machine deployment.
  2. What service account is running ArcGIS Data Store and ArcGIS Server - In both VM (Server and Datastore hosting VM) having the local administrator privileges account that is used for service account.
  3. Were there any recent changes - Yes recently we have upgraded the ArcGIS Enterprise environment to 12.1 but failed and then we have restored with old backup and again tried to upgrade and successfully upgraded the ArcGIS datastore
  4. Disk space is also sufficient.
OlaIHamed
Hello Kristofer,
One more thing came to mind after reading your update.
Since the environment went through a failed 12.1 upgrade, a restore, and then another upgrade, have you checked whether the ArcGIS Data Store 12.1 patch for BUG-000185705 is applicable to your environment? It may be worth verifying if the patch has already been applied.
https://support.esri.com/en-us/bug/arcgis-data-store-relational-store-upgrade-to-121-may-f-bug-00018...
Also, if you don’t mind sharing, could you post the full output from describedatastore.bat and any relevant ArcGIS Data Store logs around the time the validation fails? Those details may help narrow down what’s happening.
