Is it possible to edit the maxRecordCount Property of a service via Python scripting?
2324
01-20-2014 02:17 PM
GeorgeHaskett
I am using ArcGIS Server and Desktop 10.2.
I update data used by a map service on a daily basis.  For some reason the service doesn't seem to update/refresh unless I manually do so.  In order to make sure the end user is see the latest data I have been manually restarting the service.
Recently I came across an example of code that updates the min/max number of instances for a service using python.  I have been able to replicate the code, however I cannot seem to adjust the maxRecordCount property for my service, even though I can get the script to read back my current maxRecordCount settings.
Does anyone know how to change this property via python scripting?
GeorgeHaskett
Yes it is.  Alex assisted me with this on the GIS Stack Exchange site.
I altered the ESRI example that updated the number of instances by adding a reference to the Properties Dictionary and then to the the maxRecordsCount property itself.  I did have to modify their script a bit to work within my current script.  Here is the portion of code in question:
    # Deserialize response into Python object
    dataObj = json.loads(data)
    httpConn.close()
    # Edit desired properties of the service
    dataObj["minInstancesPerNode"] = 1
    dataObj["maxInstancesPerNode"] = 10
    newdict = dataObj["properties"]
    newdict["maxRecordCount"] = 5000
    # Serialize back into JSON
    updatedSvcJson = json.dumps(dataObj)
GeorgeHaskett
    httpConn.close()
