Imagery layer preparation on "ArcGIS Enterprise Advanced" version of 10.8.1
564
05-26-2023 04:27 AM
Andriy_Bashuk
There is the need to process 1- and 3- band GeoTiff large files(size 2-4 Gbytes) for further
use in ArcGIS Portal as Web Map Application's pop-up with point values.
It is thought that such a task can be performed with Imagery Layer features.
We have ArcGIS Enterprise Advanced license.
Taking into account the above mentioned, I ask you to answer the following question:
1. Is the our license bundle sufficient to fully exercise Imagery Layer features?
2. Can anybody share with me an example/blueprint/video/etc of Imagery Layer preparation that also contains a set of necessary tools/licenses/features required?
3. Can I process Imagery Layers using license bundle of "ArcGIS Enterprise Advanced" version of 10.8.1?
MiguelParedes
Greetings Andriy,
I believe that in order to implement the workflow you want in ArcGIS Enterprise 10.8.1 Advanced, you will also need the ArcGIS Image Server.
Image Server will provide you with the functionality you need in point 3)
With respect to a video that encompasses all the points you have listed, I have not been able to find one, but the following should provide you with information on Mosaic Datasets which would be the model you would want to use to make the GeoTiffs available in your Portal as Image Services.
Managing Imagery using Mosaic Datasets and Image Services.
Hope the above is of help.
Miguel
