How to update IP adress for ArcGIS Server 10.9.1
1810
5
07-28-2023 07:48 AM
MarcSIMON
I have installed Portal for ArcGIS 10.9.1 (wadesappgis001a) and ArcGIS Server 10.9.1 (wadesappgis002a) on two separated machines. The base installation was successful, but when I would done the federation, it will not work. Research with the IT people, it seems that the used WebAdaptors IP address point to a non desired IP.
Below the situation: on machine wadesappgis002a I have following situation, machine point to two different IP address.
When I install the WebAdaptor, I receive following situation:
How is it possible to force the WebAdaptor from ArcGIS Server to use IP address from machine to IP=10.36.85.14.
I had the same problem with the Portal WebAdaptor, to change the IP Adress, I used the the edit mode.
Is there somewhere a same edit mode for ArcGIS Server or another solution to resolve this?
Best Regards,
Marc Simon
Esri BeLux GIS Defense Consultant
BillFox
MVP Notable Contributor
can you remove that second NIC from the web adaptor's network settings?
MarcSimon1
No, I cannot remove the second NIC. I found a solution with update the webadaptor-config.json (D:\arcgisserver\config-store\web-adaptors\webadaptor-config.json). This works.
We will try now to include the machine IP address into the certificate to avoid this file change.
MarcSIMON
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" />&lt;!--&lt;br&gt;/* Font Definitions */&lt;br&gt;@font-face&lt;br&gt; {font-family:"Cambria Math";&lt;br&gt; panose-1:2 4 5 3 5 4 6 3 2 4;}&lt;br&gt;@font-face&lt;br&gt; {font-family:Calibri;&lt;br&gt; panose-1:2 15 5 2 2 2 4 3 2 4;}&lt;br&gt;/* Style Definitions */&lt;br&gt;p.MsoNormal, li.MsoNormal, div.MsoNormal&lt;br&gt; {margin:0cm;&lt;br&gt; font-size:11.0pt;&lt;br&gt; font-family:"Calibri",sans-serif;}&lt;br&gt;a:link, span.MsoHyperlink&lt;br&gt; {mso-style-priority:99;&lt;br&gt; color:blue;&lt;br&gt; text-decoration:underline;}&lt;br&gt;.MsoChpDefault&lt;br&gt; {mso-style-type:export-only;}&lt;br&gt;@page WordSection1&lt;br&gt; {size:612.0pt 792.0pt;&lt;br&gt; margin:70.85pt 70.85pt 70.85pt 70.85pt;}&lt;br&gt;div.WordSection1&lt;br&gt; {page:WordSection1;}&lt;br&gt;&lt;br&gt;
MarceloMarques
This is an example from an Amazon EC2 Instance that has a public IP Address and a Private IP Address.
We use the Private IP address to configure the WebAdaptors. We do not use the Public IP address nor the External URL.
WebAdaptor
ArcGIS Server > Next > ArcGIS Server URL: https://172.31.0.145:6443
Enable administrative access to your site through the Web Adaptor (checked)
Portal for ArcGIS > Next > Portal URL: https://172.31.0.145:7443
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarcSIMON
