How to disable web help
877
11-07-2025 07:22 AM
SimonSchütte_ct
MVP Regular Contributor
When ArcGIS Portal and Server are installed, a local web help is included.
How can we completely disable the help endpoint in the ArcGIS Portal/Server admin?
Example endpoints:
/portal/portalhelp/en
/server/help/en
SimonSchütte_ct
Thanks, (the correct link to your post is Securing ArcGIS Enterprise's Help Documentation - Esri Community)
The setting in Portal -> Settings does a redirect, but does not disable the underlying local help.
It also only does apply for the Portal for ArcGIS help, not for ArcGIS Server.
Summary: currently not possible to the extent required.
I created an idea here: Disable web help - Esri Community
George_Thompson
Esri Notable Contributor
SimonSchütte_ct
