How to deploy image server in a three machine configuration (Hosting + Raster analytics + Dynamic) through PowerShell DSC
1937
03-02-2021 12:04 AM
AYUSHYADAV
I am deploying an image server on multiple machines (three machines) configuration. On which I have to deploy image server as Hosting server + Raster Analytics server + Dynamic Image sever through PowerShell DSC. In the sample config JSON file for the image server, I have found the config file for a single machine deployment only.
Moreover, for the key 'ServerRole', only two variables are available i.e. 'ImageHosting', and  'RasterAnalytics'. I could not find a variable for the dynamic image server. What should I use for that?
How I can deploy an image server on a multimachine configuration?
Any help will be appreciated.
ChristopherPawlyszyn
Image Server is a licensed role for ArcGIS Server, so the only designation you should have to make in that regard is using a license file that includes the Image Server authorization code as well as the core GIS Server license.
-- Chris Pawlyszyn
