How to add Map Image Layers to the New Map Viewer Beta in Portal 10.9. - It does not have the capability now.
1743
08-03-2021 02:23 PM
AbiDhakal
The New Map Viewer Beta does not allow adding Map Image Layers to the map view. Without the capability of having this option to add to the map it will not be possible to map image layers. Please make this possible for Portal users as well, because this capability is only available for ArcGIS Online users.
Tags (1)
jcarlson
MVP Esteemed Contributor
You have to add a Map Image Layer in the Classic map viewer. You can then open the web map in the Beta Map Viewer, and the map image layers will still be there.
- Josh Carlson
Kendall County GIS
AbiDhakal
Yes, I have already tested that. It certainly works that way, but will you at some point enable the ability to directly add it to the New Map Viewer? Thank you.
jcarlson
Yes. AGOL usually shows some of the forthcoming features and improvements that you can expect to see in Portal, and the process works there. I expect this will be in 10.9.1, but we'll see.
- Josh Carlson
Kendall County GIS
