How can I quantify volume change from multi temporal LiDAR data in Enterprise?
1435
01-28-2021 03:38 AM
GerardMartin
Is it possible to compute volumetric changes with multitemporal LiDAR data using Enterprise tools?
I have seen that Ortho Maker can compute volumetric changes from drone imagery, but I only have LiDAR data or derived rasters, and also I don't have any knowledge about orthorectification. URL: https://enterprise.arcgis.com/en/portal/latest/use/cut-and-fill-volume-calculation.htm
More precisely, I would like to make exactly the same proces described in @AshBarnes post for ArcGIS Pro. URL: https://community.esri.com/t5/arcgis-mapping-and-charting/how-can-i-quantify-volume-change-from-mult...
Thank you!
JonEmch
Hello there Gerand,
   Thank you for your question! At this point in time, I do not believe LiDAR volumetric change analysis is supported in ArcGIS Image Server / Raster analytics tools. At the current release, you are able to create / work with raster products based off of LiDAR but not work with LiDAR itself.
I will continue to research this and update the post if I find anything. Please let me know if you have any additional details.
Keep on keeping on!
