Hi, people!
I have a python application that need make monitoring of logs, one of them is the AGS's log file... but, how can I access this log file?
What's specific path? Is it a XML??
Tks!!
Erik,
You should be able to find your server logs here, they are .txt files.
C:\arcgisserver\logs\YourServer\server
You may also find this resource page useful:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Good luck!
-Dan
Erik,
Good luck!
-Dan
Erik, if Daniel's response answered your question,dont forget to mark his comment as the correct answer so this thread can be closed. Thanks.
