Hosting services are not backed up when using the ArcGIS Server Backup.py tool?
2285
07-27-2023 08:27 PM
Jin-taeKim
Hi I am Jin-tae Kim, South Korea GIS User
When I restore a Federated ArcGIS Server using restore.py
I coudn't see Hosted Data.
Does anyone know?
A_Wyn_Jones
Hi @Jin-taeKim,
The hosted services are not backed up using the ArcGIS Server backup. This is a configuration backup only.
To include all hosted data in a backup, please consider using WebGISDr https://enterprise.arcgis.com/en/portal/latest/administer/windows/create-web-gis-backup.htm
As an alternative, you can backup the Datastore content alone using the following: https://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm#...
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
MiguelParedes
Greetings @Jin-taeKim
What version of ArcGIS Enterprise are you backing up?
According to the help pages for the Back UP utility, it should backup "... the ArcGIS Server site configuration", but does not say anything about the data.  However, in the following article, Back up and restore the ArcGIS Server site configuration.  Please, look at the section on Restoring a backup of your site.
Did you carry out the first step:
  1. If the site has registered relational data store types, you must unregister all of them before proceeding.
If you did not, that may be the reason why you are not seeing your hosted feature layers, perhaps?
Miguel
Jin-taeKim
Hi @MiguelParedes
Thank you for your help.
Unfortunately, I restored Server without registered ArcGIS Data Store type.
The Hosted folder is checked. Why is the data empty in the folder?
A_Wyn_Jones
Hi @Jin-taeKim,
Jin-taeKim
@A_Wyn_Jones
Thank you.
I think even if the Hosted Service is not backed up on ArcGIS Server, the data is in the Data Store, so I thought it would be okay if you connect it normally.
But seeing that doesn't work, I don't think Data should work even if it's in the Data Store because it doesn't have a shell. Is it correct?
