Hi Community,
I recently created a backup of ArcGIS Enterprise using the webgisdr utility and after some struggle restored it on the new machine. I discovered that the hosted services on the new machine were working fine, however, the referenced feature/map services were not working. I figured this is because of the fact that I have not yet installed geodatabase which is PostgreSQL in our case.
Hence, I created the backup of PostgreSQL Geodatabase and restored it on the new machine successfully, however, the referenced services are still not loading. I am not sure if I am missing something here or if something additional needs to be done after restoring the geodatabase so that the referenced services start loading.
Any insights on this would be helpful.
