Hosted Services not working after configuration changes to Server
1684
09-21-2023 08:20 AM
RobMcCulley
We've been running a single tier Enterprise deployment, and decided to expand it to a two tier deployment to improve performance.  I'm following the instructions here to migrate Server and Data Store to a new machine.
Step 1 of migrating a machine running Server is to move the server directories and configuration store to a shared network location.  After performing this step, all of our hosted feature classes no longer work.  In Server Manager, the hosted feature classes are shown as "Stopped":
I've tried restarting Portal, Server, Data Store, and the original Single Tier machine.  None of those worked.
I can't see anything wrong with the Data Store.  The output of describedatastore.bat:
General information of ArcGIS data stores on FQDN1
Data store release..................11.1.0.42869
Staging location....................C:\arcgisdatastore\staging
Log location........................C:\arcgisdatastore\logs
Free disk space.....................30.00GB
Threshold for READONLY mode.........1024MB
Information for relational data store ds_oaflnz7l
Backup location.....................C:\arcgisdatastore\backup\relational
Is backup folder shared.............false
Backup schedule.....................{"schedule-starttime":"00:00:00","schedule-frequency":"Every 0 DAYS"}
Days backup retained................7
Data store status...................Started
SSL enabled.........................true
member machines.....................FQDN1
Maximum connections.................150
Owning system URL...................https://FQDN1:6443/arcgis/admin
Portal for ArcGIS URL...............https://webadapter/portal
Number of connections...............0 connection(s) to managed database
Data Store mode.....................READWRITE
Is Point-in-time recovery enabled...No
Query optimizer enabled.............Yes
Operation completed successfully.
PS C:\Program Files\ArcGIS\DataStore\tools>
The output of validating the DataStore from the Server Admin interface:
  "datastore.release": "11.1.0.42869",
  "datastore.name": "ds_oaflnz7l",
  "datastore.replmethod": "ASYNC",
  "datastore.isReadOnly": "false",
  "datastore.isConfigured": "true",
  "machines": [{
    "machine.overallhealth": "Healthy",
    "datastore.release.configstore": "1.5",
    "platform": "Windows",
    "machine.isReachable": "true",
    "hostip": "XXX.XXX.XXX.XXX",
    "name": "FQDN1",
    "role": "PRIMARY",
    "dbport": 9876,
    "initstarttime": 1695231440090,
    "healthcheck.enable": "true",
    "status": "Started",
    "adminurl": "https://FQDN1:2443/arcgis/datastoreadmin/",
    "db.isactive": "true",
    "db.isAccepting": "true",
    "db.isInRecovery": "false",
    "db.ActiveReplMethod": "NONE",
    "db.isManagedUserConnValid": "true",
    "datastore.release.pg": "14.5",
    "datastore.release.sde": "11.1.0",
    "datastore.release.geometry": "1.30.4.10",
    "datastore.release.geometrylib": "1.30.3.10",
    "db.isSiteConnValid": "true"
  "datastore.layer.extent.updated": false,
  "datastore.status": "Started",
  "datastore.isActiveHA": "false",
  "datastore.overallhealth": "Healthy",
  "datastore.lastfailover": -1,
  "datastore.lastbackup": 1684955920681,
  "datastore.isRegistered": "true",
  "datastore.hasValidServerConnection": "true",
  "datastore.validServerMachinesList": [
      "machineName": "FQDN1",
      "adminURL": "https://FQDN1:6443/arcgis/admin"
      "machineName": "FQDN2",
      "adminURL": "https://FQDN2:6443/arcgis/admin"
  "owningSystemUrl": "https://FQDN1:6443/arcgis/admin",
  "status": "success"
If I connect directly to the DataStore database using Pro, all of my feature classes are there, and if I add them to a map, the data is still there as well:
Any idea what I need to do to get these services working in Portal/Server again?
Tags (1)
DavidColey
MVP Frequent Contributor
Have you tried using the python api to start the services?  From time to time, some of my hosted feature services or vector tile services will 'stop'  I restart them using the python api.  Something like:
try:
    gis = GIS("https://yourdomain.net/portal", "your_portal_login", "your_portal_pw")
    gis_servers = gis.admin.servers.list()
    print(gis_servers)
    #message = message + "\n" + str(gis_servers)
    agshost = gis_servers[0]
    print(agshost)
    #message = message + "\n" + str(agshost)
    vtServicesList = agshost.services.list(folder='Hosted')
    for vtService in vtServicesList:
        serviceName = vtService.properties.serviceName
        if (serviceName == 'ExoticInvasiveSpeciesPoint' or serviceName == 'ExoticInvasiveTreatment'):
            print(serviceName)
            message = message + "\n" + str(serviceName)
            vtService.start()
            print(vtService.status)
            message = "\n" + message + "\n" + str(vtService.status)
except Exception:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    e = sys.exc_info()[1]
    #print(e.args[0])
    #print "Line %i" % tb.tb_lineno
    message = message + "\n" + "Line %i" % tb.tb_lineno
    message = message + "\n" + str(e)
works for me every time I encounter a stopped hosted service.
Hope this helps
