GP Service Publishing Issue
7884
12
12-31-2014 06:32 AM
BrianLeroux
When publishing a gp service to AGS server 10.22 my service is failing. It works fine in desktop though. It seems to be a problem with the sde connection file during the service creation. Taking a look at the script uploaded to the v101 folder, the esri added variable looks like g_ESRI_variable_1 = u'..\\..\\..\\..\\..\\GP_Tools\\Database Connections\\GISDB_ArcSDE(PROD Server).sde'. This path is modified from my original path to the sde connection file on my computer Shakemap_Table_Target = os.path.join("D:\\agsResources\\GP_Tools\\GISDB_ArcSDE(PROD Server).sde", "ArcSDE.dbo.EQ_SHAKEMAPS").
When debugging, AGS Server can't seem to locate that location. Is this a known bug or something I may be doing incorrectly? I am able to fix the problems by modifying the script to point that variable at a server location where i store the sde files but I am wondering if there is a better solution. I have to jump through hoops to get access to the uploaded scripts on my production server and would rather this just work when publishing.
i appreciate any and all feedback.
by Anonymous User
Not applicable
Can you publish map services successfully, or do they fail also?
BrianLeroux
I have no issues publishing map services that reference my sde DB. The sde DB is registered properly.
by Anonymous User
Not applicable
So the issue is exclusively with gp services.  What does the AGS Server log say?
BrianLeroux
Yes just gp services. Pretty basic error messages.
"FieldMappings: Error in adding table to field mappings Failed to execute (ImportWildfirePerim). Failed to execute (ImportWildfirePerim)"
As I mentioned before, it is all about the sde location variable created when publishing the service. If i hard code a correct location the service will run without issue.
DavidColey
MVP Frequent Contributor
Brian,
I'm sure you are already doing something similar, I always use sde connection files that are located in my data-store directory and never have issues publishing any type of services.  In our distributed 3-machine 2-cluster architecture, our server directories are located on a file share server, where our domain arcgisserver account has read write access to all directories and all directories are shared.
Under the data-store folder, we use a DataConnections folder to house sde connection files and file geodatabases, and a GpServices folder to store toolboxes and python scripts.  This way I am always sure everything is in a shared location.  I also use UNC paths and although server complains about that at analzye, I never then have any issues with a resource not being read or otherwise not being available to Server.....hope this helps
David
BrianLeroux
David,
We only have 1 live gis server and the directories are all local on that server. I am not allowed to access anything on that server but the server domain account has R/W access to eveything. So that means I have to publish using a local sde connection file. With map services this is fine as the DB is registered with the server.
I will have to talk to the server team to see if we can look at a similar apprach to yours where we would move the directories to a shared location.
One question I have for you is, when you publish a GP service with your UNC path to an sde file, does esri add variables that point to the location of these files? I am curious is they are recognizingnetwork paths and not changing those but if it sees a local path it makes modifications. Looking at the variables created it seems like the sde file should be copied with the service but that is not happening.
Thanks!
DavidColey
Does esri add variables?  I'm not sure what you mean
BrianLeroux
They do. If i look at the python scripts after publishing I notice new variables g_ESRI_variable_1, g_ESRI_variable_2, etc... You would notice them at the top of the python script.
Here is what I wrote in my initial post describing my issue.
"Taking a look at the script uploaded to the v101 folder, the esri added variable looks like g_ESRI_variable_1 = u'..\\..\\..\\..\\..\\GP_Tools\\Database Connections\\GISDB_ArcSDE(PROD Server).sde'. This path is modified from my original path to the sde connection file on my computer Shakemap_Table_Target = os.path.join("D:\\agsResources\\GP_Tools\\GISDB_ArcSDE(PROD Server).sde", "ArcSDE.dbo.EQ_SHAKEMAPS")."
DavidColey
Now I understand.  I'll check and reply back
