Get earthquake coordinates from local file rather than usgs
1453
03-19-2017 08:07 AM
EngrUmair
I have copied the code from ArcGIS API for Javascript code samples of Geodesic buffers
Did all steps required to show earthquake points on map.
It worked, but the problem is that get coordinates from csv file that is located in USGS server, but I downloaded that into local server but I don't how get coordinates from local csv rather from USGS.
Because I want to show my own coordinates,
I have done some work around using sample code of CSVLayer in another file which shows what I needed, although I need to do the same with GEODESIC buffers.
Could you please share your suggestions?
THanks in Advance.
