Utility network analyst: why setting flow direction needs to be in editing mode?
1448
03-18-2017 01:53 PM
JamalNUMAN
Legendary Contributor
Utility network analyst: why setting flow direction requires editing mode?
The “set flow direction” is kept deemed unless the editing tool is started. Why the set flow direction needs editing mode?
Thank you
Best
Jamal
Jamal Numan
DanPatterson_Retired
Because you might be changing the direction of flow.  Similar to editing the physical geometry which requires an edit session (for example flipping a line's direction flow direction documentation)
JamalNUMAN
Thanks Dan.
Jamal Numan
