Hi All,
Our organization is using ArcGIS Enterprise 10.9.1.
I have published a single geoprocessing tool as a web tool/geoprocessing service to our ArcGIS Enterprise. The service gets published successfully. However, it isn't getting started and Service failed to start error message is generated.
Looking at the logs the following error messages are present
On researching on this further I came across the following link : https://support.esri.com/en-us/knowledge-base/error-services-containing-process-crashed-servicename-... however, python paths are correctly configured at my end.
Any insights on how to resolve this would help.
Some troubleshooting steps you can try:
Thank you for your inputs @Omar_A. I went through all of the above mentioned points however, still running into the issue.
I also created a simple model with just one tool and published that as GP service however, I am still facing the same issue.
I see the following error in the log.
Sorry to hear that. I'm just trying to share some other insights for this :
