Geodatabase error: DBMS does NOT support this function.
1857
06-13-2023 06:56 AM
HanliePetoors
I'm working in
  • ArcGIS Enterprise 10.7.1 on Windows Server 2016 and
  • SQL Server 2019 on Windows Server 2022
I have published a map service from a database view that generates geometry from coordinates stored in the database table. The full query is in the attached text file.
When the service is published I can successfully:
  • Query the rest end point
  • Add the service to a web map and open its attribute table
  • Create a chart for the service in web app builder
  • Use it as data source for a list in a dashboard
However, I cannot use it as a data source for a serial chart, indicator or pie chart in a a dashboard. When I try to do this, I get  a SEVERE entry in the server log with the error message shown in the subject of this post.
Does anyone know what is going on and if there is a way to fix this or work around it?
Hanlie
