Geocode Service - UICLSID
2415
04-01-2014 05:36 AM
StevenMenefee1
When I check my ArcGIS Server logs, a lot of times I run across the following "Warning" message coming from our composite geocode service (that is being consumed by a flex web portal as well as a batch geocode routine):
Property 'UICLSID' cannot be modified (propMods parameter).
I've attached a screenshot of a search (most likely from the batch routine) and the subsequent warning.
It seems like it's benign because the geocoder has always worked just fine.  However, I'd like to get it out of my logs if I could.  Does anyone know how I might do that?  Any help would be appreciated, thanks!
DanMcCoy
We have the same message.  Did you ever find out how to clear it up?
Dan
