Generate renderer problem on layers which have subtype
1398
01-15-2018 06:33 AM
Musa_SerkanArslan
I am trying to use generate renderer for dynamic map service layer. It is working fine except if the layer has subtype and the field has coded value domain. In this situation it is not grouping the values, listing the values as multiple.
I am using ArcGIS server 10.5.1
Is there any solution for this?
Thanks...
AdrianWelsh
MVP Honored Contributor
Musa,
There might be some solutions listed in this thread:
Problem with subtypes in feature service
Give those a try or check out this article for more ideas:
00085: Layer uses an unsupported renderer—Documentation (10.3 and 10.3.1) | ArcGIS Enterprise
Musa_SerkanArslan
Thank you Adrian for your response. But i try several symbology alternatives according to their comments but nothing changed.
