Forming a field of type geometry in Geodatabase
3281
12-06-2013 03:12 AM
AnatoliiTerentiev
Dear Gurus !
There is a table events with fields X, Y - containing the coordinates of points, which must be registered in the geodatabase. Created geodatabase cuks_gdb with standard tools of arcgis desktop 10.1. Table events copied in geodatabase :
select * into cuks_gdb.sde.events from cuks.dbo.events
3 . In the cloned table added field "shp" type geometry.
4 . Formed a field value by field values �??�??x, y:
update cuks_gdb.sde.events set Shp = geometry :: STGeomFromText ('Point (' + ltrim (STR (x, 99, 11 )) + '' + ltrim (STR (y, 99, 11) ) + ')' , 28406 );
All formed , error messages were not. But when I try to save changes in any field then I get an error message
The parameter type cuks_gdb.sys.geometry is invalid. Parameter name: value
How to fix ?
WilliamCraft
MVP Alum
I think you would need to register your "cloned table" as a layer with ArcSDE.  To do this, refer to the SDELAYER -O REGISTER command (http://help.arcgis.com/en/geodatabase/10.0/admin_cmds/support_files/datamgmt/sdelayer.htm) making sure that your -l parameter is something like -l cuks_gdb.sde.events,SHP.  Typically, the geometry column for registered layers is SHAPE but since yours is SHP then you'll need to specify it correctly during this type of manual layer registration.
by Anonymous User
Not applicable
Original User: aviabunin
Thanks for answer, I will see. But some additional thoughts.
A few additional thoughts.
1. Is there are any tool to form geometry field from x,y - fields?
2. Is there are any other way to form needed table in geodatabase from x,y-table in sql server?
3. The initial problem is , that service on the table with ObjectID and Shape fields not worked - data not saved in the example with EditorWidget. Only delete operation work well, and normally executes update operation , when I test feature service in arcgis,com.
4. Can I update and add features in geodatabase from arcgis desktop 10.1 and how I can do this?
5. I have registered tables in geodatabase with tools in arcgis desktop - this is not enough?
6. If I have formed geometry field  of geodatabase table as previously described - this is not enough for CRUD operation in sql manager? from arcgis desktop?
Thanks in advance!
AnatoliiTerentiev
