Original User: aviabunin
Thanks for answer, I will see. But some additional thoughts.
A few additional thoughts.
1. Is there are any tool to form geometry field from x,y - fields?
2. Is there are any other way to form needed table in geodatabase from x,y-table in sql server?
3. The initial problem is , that service on the table with ObjectID and Shape fields not worked - data not saved in the example with EditorWidget. Only delete operation work well, and normally executes update operation , when I test feature service in arcgis,com.
4. Can I update and add features in geodatabase from arcgis desktop 10.1 and how I can do this?
5. I have registered tables in geodatabase with tools in arcgis desktop - this is not enough?
6. If I have formed geometry field of geodatabase table as previously described - this is not enough for CRUD operation in sql manager? from arcgis desktop?
Thanks in advance!
