FieldMaps for ArcGIS at Enterprise 10.9
4773
10
05-07-2021 12:50 PM
DavidColey
MVP Frequent Contributor
Hello - I can't seem to find whether or not I should uninstall my current FieldMaps app from my Portal at 10.8.1 before I run the upgrade to 10.9. I can see from the 'What's new' that Field Maps is now included at 10.9, but I can't seem to find anything that says I should uninstall the latest 10.8.1 version.. . . I'm assuming I should but, I don't know for sure-
Thanks-
Tags (1)
JonEmch
For Insights I would suggest going to the Insights community  - https://community.esri.com/t5/arcgis-insights/ct-p/arcgis-insights or logging a support ticket. Connector types can be a bit finicky, so it may require a support case. As for fieldmaps being inaccessible, can you take a look at Portal logs to see if anything is present there?
Keep on keeping on!
