FeatureSetByName or ByID with Flat Table?
1816
08-24-2020 08:08 AM
InvenergyGIS_User
I am getting no records returned from a FeatureSetByID Arcade expression for a flat table in my $map or $datastore.  Is this expected behavior?  Does the FeatureSet function work on flat tables or only on spatial data?
FeatureSetById($datastore, "2") returns the field names, but no data.
Using ArcGIS Enterprise 10.7.1
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Invenergy GIS User ,
Arcade can work with flat tables and featurelayers.
Did you construct this line manually or did you use the interface to create it, like this:
If the test returns an empty featureset (just field names) you should check is the service is up and working correctly.
DavidTreering1
Thanks, Xander Bakker‌!
I used the interface as in your screenshot.
I gave the records in the flat table a fake lat/long and republished so it became a spatial featureset.  Then the FeatureSetByName and ByID work fine.
You said Arcade works with flat tables, which I see is true, but that particular function just gives me empty featuresets.
XanderBakker
Hi David Treering ,
I'm glad you could make it work, but it remains strange that without the coordinates it is not working for you. What version of Enterprise are you using?
DavidTreering1
