Failed to execute Geoprocessing on ArcGIS Server
4855
8
07-25-2017 08:44 AM
AnasELMALEKI1
I am trying to publish a working model created using Model Builder which returns a significant result when executed on ArcMap. After having published the model on the ArcGIS Server, it doesn't work, here are some snapshots :
Model Builder
Execution on ArcMap and visualization (red rectangle)
After publishing the geoprocessing (executed from "orange box")
We get a error message (red circle)
We need help please.
Thanks in advance.
JonathanQuinn
Esri Notable Contributor
Have you looked at the link on troubleshooting GP services?  The section on enabling Info level messages will be particularly useful.
AnasELMALEKI1
Thanks, I activaed info, here's the message :
I couldn't resolve the problem.
JonathanQuinn
So Google Translate tells me that the error is "Invalid return value".  Is that correct?  If so, can you check the directory manually using ArcMap or ArcCatalog and verify that the data it's expecting is in the scratch geodatabase?  Basically, follow the path in the error to see if the data is there, which is outlined here.
AnasELMALEKI1
You're right, the error is invalid return value.
I explored scratch.gdb, I found that it doesn't contain any result of the geopocessing.
Is it a problem of writing permission?
JonathanQuinn
It's a character issue.
I doubt FGDB feature class names support an accented e.
AnasELMALEKI1
I tried the same process with a simple e, it didn't work.
JonathanQuinn
You can simplify this and just take the input data and save it to the scratch workspace.  If that works, then I'm not sure why it wouldn't when you add the rest of the tools.  You may want to reach out to technical support.
Dr__Syed_AliNaqi
Have your problem solved?? I have one clue for the solution but I need your model snap/pic in English version before final statement.
