I have a tricky problem when I want to use the Export web map tool as a service for printing in ArcGIS Viewer for Silverlight.
First, I use ArcGIS for Server 10.1 Sp1 and the ArcGIS Viewer for Silverlight 3.1.
The problem occures on one of my feature services where I have ownership-based access control set. The service is configured so the user can't see (or edit) objects created by another user. I use Windows authentication on ArcGIS Server so the user doesn't have to sign in to the webb app.
When a user try to export the web map using the Export Web Map service I have created, the objects in the feature service created by the user aren't visible. I have found that the Export Web Map service uses the ArcGIS Server account while calling the feature service instead of the users account. Are there a way to configure the Export Web Map service to use the same account as the user?
Thanks for all help I can get!
/Per Angerud
