I have a question about table joins and relations in ESRI REST FeatureService.
I created an mxd file with several layers and managed to create a REST service out of it. I can see all layers, symbols etc. Here everything works fine.
Today I wanted to add a join to a layer. I joined another layer from the same document. In ArcMap everything worked fine. I could see the joined fields. When I uploaded the service (which by the way did not want tu update itself and I had to delete the service and publish the mxd as a new one) I found out that all my columns in the layer, that was the owner of the join, disappeared. In FeatureServer I had only the OID and geometry.
When I looked at MapServer service definition of this layer - everything was fine. All the fields, along with the joined ones, were present.
Similiar thing happens with relations. I create a relation to a another layer in the same mxd file and its definition is visible in MapServer and not in FeatureServer.
Did anyone come accross this error ? What I might be doing wrong?
And one more thing. Is there a way for FeatureServer to show layers hierarchy like MapServer does ? With group layers visible ?
I use ArcGis Server 10.3.
It runs on Windows Server 2012 R2 Standard (64 bit).
If anything written above is unclear please let me know and I'll update my question.
