Error while publishing service in arcgis 10.1 for server
3582
11-10-2012 04:28 AM
IFTIKHARALI
when i am publishing an MXD file from ArcMap 10.1 it gives me the Error,
" The sever is not ready for publishing.
Please check if the publishing Tools on the server (System/Publishing Tools) are started."
please help me to fix this issue.
nicogis
-is System/Publishing Tools in status:started?
-have you enable ssl?
-have you installed sp1?
nicogis
IFTIKHARALI
sir the status of the Arcgis server 10.1 was stopped, i tried alot to start it but each time it will give error,
Then i reinstall the arcgis server it was fine now and in working condition.
i have published the services i.e all the Mxd, now i want to use it in Flex 3.0.
i am totally new and now want to learn it and make an application.
using arcgis server 10.1 and Flex.30.
DerekLaw
Esri Esteemed Contributor
Hi there,
... i have published the services i.e all the Mxd, now i want to use it in Flex 3.0. i am totally new and now want to learn it and make an application. using arcgis server 10.1 and Flex.30.
FYI, please checkout this Esri live training seminar session to help get you started:
Getting Started with the ArcGIS Viewer for Flex
Hope this helps,
