supportsSSL on generateToken
3107
11-16-2012 06:27 AM
JordanParfitt
I'm new to ArcGIS server. I'm trying to call the generate token command in .NET, but it keeps giving me this response:
{"ssl":{"supportsSSL":false}}
Here is the URL I am using:
[ip:6080]/arcgis/admin/generateToken?Referer=[ip:6080]&username=[username]&&RequireSSL=False&f=json&password=[password]
Is it something in my settings? I don't have an SSL certificate.
Thank you in advance.
JordanParfitt
Looks like I should have been doing a post, not a get. Downloaded Postman for Chrome and it works in that.
nicogis
you can create a self certifcate.
in http://server : port/arcgis/admin/security/config what have you configurate in Protocol ?
Minimally, the Generate Token operation must be accessed over an SSL connection as it requires an exchange of administrative credentials
JordanParfitt
Thanks for your response. That page looks like this:
Security Configuration
Protocol:  HTTP Only
Security for virtual directories enabled: false
Authentication tier: GIS_SERVER
Authentication mode: ARCGIS_TOKEN
User Store Configuration
Type: BUILTIN
Role Store Configuration
Type: BUILTIN
JordanParfitt
