Error: ???service started with error???the base definition string sss is invalid???
3450
01-14-2013 02:14 AM
by Anonymous User
Not applicable
Original User: [email protected]
Error: �??service started with error�?�the base definition string sss is invalid�?�
Despite the fact that the �??analyze�?� of the �??service editor�?� doesn�??t show any errors, I got the message shown in the screenshot below:
[ATTACH=CONFIG]20690[/ATTACH], [ATTACH=CONFIG]20691[/ATTACH], [ATTACH=CONFIG]20692[/ATTACH]
What is meant by �??the base definition of string sss is invalid�?�
i tried to start the service again abut i got the message below:
[ATTACH=CONFIG]20694[/ATTACH]
What might be the issue?
Thank you
Best
Jamal
AlagappanAL
I am facing the same issue. While publishing the map service in arcgis server 10.1 with a SDE layer, getting the issue. Any clues to solve it.
Thanks !!
by Anonymous User
Not applicable
Original User: nidhinkn
You can take a look at this forum post.
http://forums.arcgis.com/threads/66247-base-table-definition-string-is-invalid
