Error Registering a Snowflake DB as Datastore
645
11-13-2025 11:18 AM
emoreno
Using Enterprise 10.9.1 and ArcPro 3.1.7
I am trying to register our Snowflake database as a datastore to our Server, but during the validation process I receive the error "the connection property set was missing a required property or the property value was unrecognized. The specified data source (or database) is invalid []."
For background, I am using a stored username and login and have verified that the Snowflake ODBC is on the ArcGIS Server Machine, as seen in this community post: Issues when registering a Snowflake database - Esri Community
I can connect successfully to the Snowflake database in Pro but registering it as a datastore seems to be where the issue is. I believe we run a multimachine deployment if this is relevant. Does anyone have any ideas as to how to solve the issue? Thanks!
Priya_Das
Hi @emoreno
Considerations:
  • The Snowflake ODBC Driver must be installed prior to establishing the connection in ArcGIS Pro
    • Below is the Snowflake Driver setup
Snowflake Driver Setup:
  • Download and install the latest windows 64-bit Snowflake ODBC Driver
  • Perform a Windows search to find and open ODBC Data Source Administrator
  • Click the System DSN tab and click Add and Select SnowflakeDSIIDriver
  • Snowflake Configuration Dialog
    • Data Source - Enter a name for the data source
    • User - Provide account name ([email protected])
    • Server - The Snowflake server (youraccount.snowflakecomputing.com)
    • Tracing - Set it to "4"
    • Authenticator - Set it to "externalbrowser"
  • Click on Test to confirm  Snowflake access
    • Click OK to save
Could you try registering your Snowflake database with ArcGIS Pro 2.9
I believe the compatible version of ArcGIS 10.9.1 is ArcGIS Pro 2.9: https://enterprise.arcgis.com/en/system-requirements/10.9.1/windows/databases-in-the-cloud.htm
Also you can refer to Best practices when integrating data from cloud data warehouses with ArcGIS Pro and ArcGIS Enterprise:https://www.esri.com/arcgis-blog/products/arcgis-enterprise/data-management/best-practices-when-inte...
https://enterprise.arcgis.com/en/server/11.1/manage-data/windows/connect-snowflake.htm
https://pro.arcgis.com/en/pro-app/latest/help/data/databases/privileges-cloud-data-warehouses.htm#ES...
