for a particular feature(ObjectID), MapServer returns no record found but FeatureServer shows record
486
11-16-2025 09:50 PM
codethemap
We are seeing inconsistent behavior between FeatureServer and MapServer endpoints.
Observation:
  • Querying a specific ObjectID via FeatureServer returns the record.
  • Querying the same ObjectID via MapServer returns no records found.
  • Only a single line feature is affected — not the entire layer.
Environment:
  • ArcGIS Enterprise 11.5
  • Stand-alone ArcGIS Server (not federated with Portal)
  • Data is branch versioned.
  • Service published from ArcGIS Pro to stand-alone Server.
  • No Definition Query is applied for any of the layers.
We temporarily switched the geodatabase from branch versioning  to traditional versioning, re-checked the data, and in this case the feature appears in the data in GDB.
When switching back to branch versioning, the feature again disappears from data on GDB.
Question:
What might be the cause that the particular feature is missing on the MapServer but is showing in the FeatureServer on Rest End query.
