Error publishing in Standalone ArcGIS Server 10.9 as Reference data in ArcGISPro 3.0.2
5665
02-01-2023 09:29 PM
shamnasPC
I am encountering issues with publishing to Standalone ArcGIS Server(10.9.1) as reference data using ArcGISPro 3.0.2.  The error message is "Publishing tool execution failed."
There no issue while publishing as copy all data to server.
Attached the screenshot for the logs and error message for more info
Tags (3)
2 Solutions
Scott_Tansley
MVP Regular Contributor
I can see that your Arc Pro layers is pointed to a file server beginning:  \\gisprddts
Two things to look at:
You clearly have permissions to be able to read that data.  The ArcGIS Server will be running under a different user account, i.e. "Not you".  Does the server have read permissions to the file server or the folders under it.  It could be permissions related.
Also, because you have the file geodatabase open you will have file locks present.  ArcGIS Server 'may' not like that.  You may be better to create an SD file package.  Close ArcGIS Pro, and then upload it through Server Manager so that the locks are cleared.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Scott_Tansley
Without being able to see what's going on, that sounds like there could be a firewall port that's blocking you.  We sometimes see that ArcGIS Pro is trying to publish on https://server.domain.com:6443/arcgis, and if you're in a different network zone/subnet then messages may not get across the firewall.  For now, use the workaround.  Glad you can publish.
Scott Tansley
Scott_Tansley
Scott Tansley
shamnasPC
Hi @Scott_Tansley
Thanks for you quick response.
It worked by uploading SD through server manager. But not through ArcGIS Pro even if I use sde to publish, having same error.
Scott_Tansley
Scott Tansley
shamnasPC
Thank you @Scott_Tansley
ArcGIS Server and Pro in same network zone. In fact, the ArcGIS Pro is installed on one of the ArcGIS servers machine.
Scott_Tansley
Yeah that was a bit of a long shot.  Just be careful running pro on a server if it’s prod.  They likely to compete for resources.
Scott Tansley
